creating pdf docs in publisher
we are using archicad 9 and have a problem with publishing to pdf docs, when you set up a view set in publisher and click on format folder or drawing we get the list of formats dwg, dxf etc but pdf doesn't appear in the list. This only occurs when logged on to the network as a user, when logged on as administrator pdf appears in the list.
We believe this is a permissions/rights problem and have assigned full control to the user profile but this doesn't resolve the problem.
Does anyone know how to solve this problem?
1 REPLY 1
Ben Odonnell
Mark,
Check out this link http://www.graphisoft.com/support/archicad/archiguide/SaveAsPDF.html
It may help your problem.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
