Collaborate forum
different kinds of DWG attachments to ac
hi
what are the differences between different types of dwg attachments (linking, x-ref, module, external drawing, opening dwg directly by dbl clicking)
thanks,
joseph
8 REPLIES 8
Eduardo Rolon
Read here
http://helpcenter.graphisoft.com/guides/archicad-20/collaboration-guide-for-archicad-20/interoperabi...
I always use "Place as Drawing" since you can also turn individual layers off by selecting the drawing and editing its settings. The article is wrong in that regard.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro M1 Max 64GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
Eduardo,
Could you point me to the part in the article that you think is wrong? (I just don't want to read the whole thing, you could point me faster in the right direction.)
If something is wrong in it, I will let the guys at GS know about it and they will correct it.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Eduardo Rolon
The "No" should have an asterisk, since it can be done but not from the Layers Palette or the description could be changed to "Editable Layers using Layer Command"
OS X 10.XX latest
AC25 US/INT -> AC08
Eduardo Rolon
The paragraph that contradicts it.
OS X 10.XX latest
AC25 US/INT -> AC08
Thanks, I think this single item remained in there from the times where it was not possible to turn individual layers of the DWG/DXF file ON/OFF.
I will forward this to the GRAPHISOFT documentation gal.
DGSketcher
Never noticed that option I've learned something new today
Apple iMac macOS Monterey / AC25UKI (most recent builds)
Yup, place as drawing is great.
A neat trick I use is change the layer of the placed drawing to the layer I want to import certain linework on, then turn off all but those layers in the placed drawing and hit explode. No need to clean up unwanted layers from the DWG. You do get some linetypes and possibly fill types, but at least no layers cluttering up your project.
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
ejrolon wrote:
Read here
The page in question is now corrected by GRAPHISOFT.
