dl.graphisoft.com refused to connect
fire0ntheh0le
I have tried from different web browser to download Archicad but seems thats something its not going well. I have tried to turn off my firewall: it doesnt work.
"dl.graphisoft.com unable to connect"
Can anyone help me with this matter...
Best Regards,
fire0ntheh0le
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear all,
We managed to solve the issue on our side. Could you please give it a try again?
Thank you all once again for the reports!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
6 REPLIES 6
I don't know about that website, but I can't connect to it either.
You can also download the full version with this link.
https://graphisoft.com/downloads/archicad/install/AC25/INT
If you need a different version or different language (i.e. USA, FRA, SPA, etc.) then just change them in the address bar.
If you are after an educational or trial professional license, you will still have to apply for that.
Nah its not working, I've tried ur download link but when I click to download the Archicad it redirect me at the same link, so again its showing the same issue:
dl.graphisoft.com refused to connect.
Ah, so that is where that address come from.
No it is not connecting.
All I can do is bring it to the attention of @Minh Nguyen to see if he knows anything about it.
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi all,
Thank you very much for the notice and I am very sorry for the issue!
At the moment, I have already alerted the responsible team. As soon as we have some news I will let you know!
Thank you very much for your patience!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear all,
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Thanks Minh.
