.dwg to 3D mesh
Hello
could somebody tell me how to make a 3D mesh from a .dwg file???
pls note I use archicad 17 & I am relatively new to the program!!
thanks in advance!
2 REPLIES 2
Eduardo Rolon
If i remember correctly:
1. Verify that the Autocad file has 3D information. AC cannot create a 3D mesh if there are only 2D elements. While you are at it clean up the file so you only have what you need.
2. Go to File ->Libraries and Objects -> Open Object
3. Select "Browse for a Folder" and check that you have DWG as an option
4. Select the DWG file
5. Place the Mesh as an object and use Convert to Morph if you need to edit.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
David Maudlin
Lucky 95:
More information would help: is the dwg file a 2D site plan, a 3D dwg file, or some other view of the site? If you have the site as a properly formated txt file or xyz file, ArchiCAD can import that data a create a Mesh automatically (Place Mesh from Surveyors Data command).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
