dxf-dwg translation setup
How can I convert Plot Maker File to DWG and get plot style table CTB instead of STB.
I am confident that has to with Translation file. I have tried everything but I guess I am not seeing it.
Thanks
3 REPLIES 3
Anyone
Maybe I was not clear with my question.
Please let me know
Thank you
TomWaltz
Thanks
It's not an option in the Archicad translator.
The only way I know if is to create a DWG template (with AutoCAD) that has a CTB pen table assigned and use that template in your translation.
Tom Waltz
This will work in creating a DWG that is set to take CTB as opposed to STB however because AutoCAD does not save CTB within DWG files, and AC doesn't create a CTB file for you. the only way I found is that I had to go in AutoCAD to create a new CTB and then I would email that to our consultant along with the DWG files. (I only needed to create the CTB once since I am using the same line weights for all sheets and all projects.
Learn and get certified!
