2007-07-16 05:42 PM
2007-07-16 05:53 PM
2007-07-16 09:54 PM
2007-07-16 10:00 PM
2007-07-17 03:38 PM
2007-07-17 07:36 PM
2007-07-18 10:12 AM
kliment wrote:You might want to use the File Linking option, to update the original geometry after the export and have it automatically reflected in 3ds max/VIZ.
Why would you need dwg for this?!?
2008-11-20 11:16 PM
2008-11-21 09:39 AM
stefan wrote:This is indeed an older post. And if I'm not mistaken, Revit models are now transferred to 3ds Max using the FBX format (originally from Kaydara FilmBox, which, in the form of MotionBuilder was later sold to Alias, which was later sold to Autodesk).kliment wrote:You might want to use the File Linking option, to update the original geometry after the export and have it automatically reflected in 3ds max/VIZ.
This works when you mainly prepare it to be structured according to layers.
This is also how Revit files are linked to VIZ or 3ds max: as DWG documents!
2008-11-21 10:00 AM
