get alot of unreadable DWG/DXF drawings
Aussie John
I find a lot of my consultants cant read my DWG created from Plotmaker. They get a general error.
I've turned off hairline and vectorial fills.
At a bit of a loss
Cheers John
[/size]
Djordje
Ace
John,
I had this problem when sending out drawings with lots of fills.
Try the following (to pinpoint the culprit);
- save from plotMaker 3.1 with the XRef option; your consultants can check drawing by drawing
- check the modelspace of the drawings in ArchiCAD; if it loads for ages, then this is a sure sign your fills are too much for AutoCAD, never the one for hatches as they are called there.
Especially if you have symbol fills, that is a killer ...
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje
Ace
Djordje wrote:
John,
Oooops ... just saw you are on 8.0
I did have the same problem in 3.0R2 INT, it was solved in R3.
Workaround: publish the DWGs from ArchiCAD (more intelligence anyway) and just the paper spaces from PM. Then it can be relinked in AutoCAD ...
Some workaround, huh?
Djordje
HP Omen
