group by material
David Bearss
Am dabbling with a materials take off. Am wondering how to get sub totals based on exterior material surface. I have a basic test set up with two wall surfaces. Easy enough to get a total but how to get sub totals on each material?
David Bearss
Archicad 18/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
8 REPLIES 8
In the scheme settings add a flag next to the outside surface.
David Bearss
Seriously that was crazy simple. Thanks so much Barry.
Soooo, have to say though, why a cryptic flag symbol? Why not a button that says something logical like; Sum.
David Bearss
Alienware 17 R5
Even in the help files it doesn't really have a name - they just refer to it as the flag icon ...
• Display the flag icon next to the one schedule field for which you want to display subtotal cells in the schedule, as well as sum/quantity cells.
Actually you should place it next to the are field rather than the surface field - although in this case it makes no difference.
And it will only work so long as you have the sum/count active (middle button) on the area field.
It may have something to do with the fact that "Flag" is a computing term indicating an ON/OFF, True/False state:
https://en.wikipedia.org/wiki/Flag_field
In this case the "Flag" means the item based on which Sums need to be calculated.
David Bearss
Laszlo,
The IS is a wonderful powerful tool but it seems this little example of a cryptic user interface could be improved to make it more intuitive and user friendly. Interesting that the help files vague about it.
Thanks for help and info.
David Bearss
Alienware 17 R5
David Maudlin
Help Tags for these items would be a plus.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Erika Epstein
Help tags would be good. There is documentation is in the Archicad Reference Guide
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
David Bearss
Thanks Erika,
That is the all explaining simple paragraph that I was not able to be lucky enough to find.
David Bearss
Alienware 17 R5
