Ah, so this is not a schedule but just text in a box (or with the frame turned on)?
If it is all one text element, you can only have one justification style per line of text.
You would have to split the text into two separate columns, one for the description and one for the amounts.
Then you could position and justify each separately.
However with text there is no justification for the decimal position.
So you would have to justify that column by the right hand side and make sure you always had the same number of decimal points and units of measurement text.
