Collaborate forum
insert external dwg to its zero
Hello,
Dwg file contains exact site location with wolrd coordinates.
I would like to insert it into archicad to its original location, not to archicad zero.
Thanks for the help
2 REPLIES 2
You really do not want to do this as any data may be very far from the origin which will lead to all sorts of issues, just do a search on this forum.
Ideally the project origin should be at the bottom left of the project / site and use the project location to set the coordinates for the zero
Regards
Scott
Erwin Edel
I generally don't have any problems inserting a DGW at origin on a worksheet.
If you get any problems you could keep the original working unit (most likely meters instead of mm), this scales the problem down by a factor 1000.
That said, the model is always on the origin to avoid the problems Scott refers to.
The location you set at Project Location (CTRL + W) is the real world location of your project origin. You might need to convert cartesian to GPS, depending on your local standards, to get an accurate lattitude/longtitude.
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
