Collaborate forum
keynote scheduling
jkershaw
hi all -
After working in AC for nearly 20 years, I decided to make my first foray into keynote scheduling. I spent 30 minutes and built a schedule that reads two Property Values that I created ("keynote" and "keynote number").
To test, I assigned values to three elements - a column, a slab, and a wall. I labeled two of these elements on the plan, but did not label the third.
First question:
Can I set up the schedule so that IF an element does NOT have a label associated to it, THEN it will not show in the schedule? Many elements show in various views, but I do not want the keynote to be listed just because the element is in the view.
Second question:
Is there no way to "top justify" the cells in the schedule?? We often have very long notes, and "center-justification" is not only graphically inferior but also less clear.
iMac Retina 5K 27", 3.8 GHz 8-Core Intel Core i7, 72GB RAM
10.15.7 Catalina
using AC since version 4.5
15 REPLIES 15
jkershaw
example of poor justification behavior (question two)
10.15.7 Catalina
vfrontiers
I feel your pain, brother!
The way I would have gone about it is this...
Use ELEMENT ID for the KEYNOTE NUMBER (with the ability to override)
Place an AUTO LABEL that reads the keynote number
In the script of the note, have an external file that lists all the notes and numbers and have it perform a simple lookup to extract the note..
(Bonus, you could have a 2nd set of notes for the same number so one could be long and the other short and you could read either one by a switch)
So what happens is the NOTE LABEL itself gets injected with the actual notes.
The bitch is that ArchiCAD (after 33 years) CANNOT SCHEDULE LABELS!!!!
In essence, you could do the same thing by making the LABEL an OBJECT and read those... It just can't ASSOCIATE itself to the thing your pointing at.
I had just posted the sentiment elsewhere on this forum... (and I also posted it 3 years ago and 5 years ago...).
Duane
Visual Frontiers
AC22 6021:|: AC24 4007:|: Enscape3:|:TwinMotion
DellXPS 4.7ghz i7:|: 8gb GPU 1070ti
vfrontiers
Guess it's time to look into CadIMAGE Keynotes!
Not sure I like the monthly fee idea though...
Duane
Visual Frontiers
jkershaw
Thanks, Duane -
I knew when I posted that it was an issue of AC being able to get 95% of the way there.... only to have it fail at the last 5% making it useless.
So close, yet so far.
10.15.7 Catalina
vfrontiers
maybe AC45?
Duane
Visual Frontiers
DGSketcher
Duane, you make that sound easy! Care to elaborate? I have an excel file I would love to link with a simple look up.
Thanks
Apple iMac macOS Big Sur / AC24UKI (most recent builds)
vfrontiers
Because I have stopped at the "Can't schedule labels", I guess I've never had hands on experience here.
Page 560 in the current(AC21) GDL manual is where I'd start. The section called TEXT I/O... and in this case the subheading READING VALUES...
Duane
Visual Frontiers
DGSketcher
Ahh. Guess I misread read your post Duane, I thought you had this working. Thanks for the GDL pointers though, I will have a look and see if I can get it to work with my own labels.
gpowless
Wrong post
Intel i7-6700@3.4GHz 16g
GeForce GTX 745 4g
2-HP Pavilion 25xw
Windows 10
Archicad 23 USA Full
alemanda
Beginner
Gpowless,
I think you posted in the wrong tread.
I was asking about the piping slope in another tread ... I ask the moderators to move these two posts in the right place .
thanks for the answer. I'm playing a bit with the MEP modeler and I catch the spirit of the tool. Your suggestion is helpful.
In case I want to change the slope of my piping after drawing it for the first time, how to do it?
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
I have the exact same question as the OP and am wondering if this is possible now with AC22?
I want to create an exterior finishes schedule that only picks up the auto labels I have placed against certain elements in the elevations. I created a property under Product Info called 'Finish Code' and then allowed it to be a property for all elements. Then I just enter the abbreviation for the finish against the element wherever I want to place the label. BUT when I try to schedule the finishes, it picks up all the elements for which I have not placed labels (and have empty data against Finish Code) and it picks up elements for which I've given data against the 'model' property but which I intended to also give further info on the finish product.
Thanks for any insights...
In the 'Criteria' section of the schedule, add a criteria that filters the 'Finish Code' property and set it so that it "is not" and leave the value empty.
So ... Finish Code is not ________
This should filter just the element that have a finish code with a value in it so only those are included in your schedule.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Thanks Barry!! That makes a lot of sense - it didn't quite work like that but you helped me figure it out.
Here is what I learnt in case anyone else faces the same problem.
1. Don't create the schedule under components otherwise it won't work correctly; create it as an elements schedule
2. When adding the finish code to the schedule criteria, select 'has custom value.' For some reason, if you select 'does not contain' and leave value as blank, it will still bring up all of the elements that have finish code available in the properties, even if you haven't entered anything against them.
3. I had 'model' as a schedule field, but it didn't have bidirectional editing available so I went into property manager and edited the default 'model' property that was available under product info. I changed data type to 'tags list', default value as 'value' and left blank and then made available to all classifications.
I've attached a document.
Sarah wrote:
1. Don't create the schedule under components otherwise, it won't work correctly; create it as an elements schedule
I have to disagree. There are certain cases where you would like to use it. All 3 types have a bit different specific and query different data form model.
Yes I am sure there are specific cases. However my post above is referring to a specific case as per whole thread. In this specific situation, I found it didn't work.
