2013-12-15 06:04 AM
2013-12-15 06:37 PM
2013-12-16 02:56 AM
2013-12-16 02:36 PM
Barry wrote:I took a look at this, but it looks like the Schedule is getting the units from the Calculation Units & Rules Preference, not the Dimensioning Preference, so I don't see how this can be done in a single file.
But if you are getting the areas from fills in your plan you could save 2 views of your schedule and set the units in each to be what you require. You would have 2 separate outputs of the schedule but that might be workable.
2013-12-17 01:29 AM
David wrote:I should have actually tested this rather than just typing.Barry wrote:I took a look at this, but it looks like the Schedule is getting the units from the Calculation Units & Rules Preference, not the Dimensioning Preference, so I don't see how this can be done in a single file.
David
2013-12-17 02:12 PM
Barry wrote:I think combining the Dimensioning and Calculation Units & Rules Preferences would help, there is also the case where Curtain Wall Doors can only be scheduled in decimal feet (not feet and inches) since their units come from the Calculation Units & Rules. It can be confusing.
Yes it uses the calculation units which aren't saved with a view rather than the dimension units which are.
2013-12-17 07:05 PM
David wrote:I agree David. I have just been scheduling wall skins to show how priority based connections affect wall surfaces and volumes. All linear measurements are in decimal feet. If they were in feet and inches they'd match all the dimensions in the rest of the project!
David
2013-12-21 10:49 AM
