Collaborate forum
map custom properties to ifc
gdford
Is is possible to map custom properties to IFC?
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-25
Win 10 - ASUSTeK Zephyrus M GU502GV - 64 bit
Intel(R) Core(TM) i7-9750H CPU @ 2.60 GHz
16.0 GB ram
6 REPLIES 6
poco2013
As I understand, You can map custom properties to ifc properties by using the IFC translator and the property mapping dropdown dialog by setting a mapping rule for the ifc property. i don't believe that you can use expression properties though -- could be wrong
Gerry
Windows 10 - Visual Studio 2019; ArchiCAD 25
Just double checked -- apparently they can
Gerry
gdford
yes - i just discovered and tested - property expressions can be mapped to IFC.
Gerry - do you know if anyone has automated IFC mapping of custom properties based on schedules?
Gary Ford
Archicad 12-25
16.0 GB ram
Don't believe so. What did you have in mind?
Gerry
Well, lets say I have 500 custom properties I want to export with an IFC model. All of the properties are scheduled via various schedules. It looks like I would have to make 500 edits in the IFC translator to accomplish this task. So I am wondering if this could be accomplished via the API to generate the mapping using the schedules as a guide
Gary Ford
Archicad 12-25
16.0 GB ram
This is definitely possible. Our reseller supplies a template with a very detailed set of properties that they have all mapped to IFC export.
When I last looked at the interface for this, it didn't seem to be very user friendly or for those new to IFC perhaps. I am glad they offer this service, since the task seems daunting.
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
