moving dimension text
Hello.
I put some dimensions on my drawing and moved some of its text. Now I rotated the canvas. The dimensions adapted, but the dimension text I moved did not. How can I solve this?
Thank you.
1 REPLY 1
In other words, I need to revert the text to its automatic position. Is it possible to do this in any other way but select the text one by one and revert it to its initial position? Thank you.
And I have another issue connected to dimensions, namely: how can I change Archicad's dimension settings, so that it does not push the dimension text to the right when it does not fit etc? Can such settings be changed?
Thank you again.
Learn and get certified!
