Collaborate forum
nVidia Omniverse + Archicad
Hi guys,
Does anyone know, what it is and how end user can benefit from that? Is it something like GeforceNOW, but instead for games it is for AEC industry?
https://www.nvidia.com/en-us/omniverse/architecture-engineering-construction/
Let's share some thoughts!
Best,
Karol
OPENBIM does works!
ArchiCAD 22/23/24/25/26
AMD Ryzen 7 3700X, 128GB RAM, GeForce RTX 3070, Windows 11 Pro
MBP 14 M1 Max 32GB
http://www.bimfaktoria.pl/
10 REPLIES 10
Nvidia Omniverse is a collaboration and visualization platform, which is currently in the open beta stage.
It is using the USD (Universal Scene Description) open-source file format. It will have these Connector plugins for various applications (currently Revit, Rhino, SketchUp, and Archicad all have it). Through these Connectors, applications can send their data to a central database for collaboration and physically accurate visualization (AFAIK). I am not sure about this, but I think the plan is for the data exchange to be bi-directional, so any data synced to the Nvidia server gets synced to all connected applications. I don't know if it is true, would it mean that it could become a rival to federated models or to IFC file exchange. This is not clear to me at this moment.
The database and the live sync are handled by a server called Nucleus. I think it runs on Nvidia hardware (GPUs).
Nvidia also announced Omniverse Enterprise, which, for a team of 25, costs $25K for the Nucleus server (mandatory) and $1,800 per user per year. So it is not going to be a cheap solution. It will become available in the summer.
So, in summary, I can imagine a whole ecosystem will be built around Omniverse.
It seems to me that both Nvidia (with Omniverse) and Epic Games (with Unreal Engine) are going after the AEC collaboration and visualization market.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Gorazd
I have tried to test it, but cant figure out, how to install archicad exchange addon. It says installed, but there is no menu in archicad 24
Gorazd Rajh
AC 25, Ryzen 9 5900HS, 48 GB RAM, RTX 3080, Win 11
I have not tried installing this, but have you looked in the Work Environment to see if there are any new Omniverse commands/menus that you can add yourself?
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Gorazd
No new commands in WE. Installation has finished successfully, but there is no menu.
Gorazd Rajh
A Palette or a Toolbar maybe?
Erwin Edel
https://www.nvidia.com/en-us/on-demand/session/omniverse2020-om1267/
This shows Revit in combination with some other software, but I think it demonstrates the intended benefits for AEC software.
It looks flashy, but I'm wondering about the amount of instances over the course of a project where you would have several disciplines working on one project at the exact same time.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Hello! I was wondering the same and I just discover that to install the connector, you have to do it from the launcher, go to the exchange menu, and there you will see a connector menu, just next to apps ones. Then you will need to follow the instructions to make it work I'll leave a link.
https://docs.omniverse.nvidia.com/prod_launcher/prod_launcher/overview.html
I hope this helps
Regards.
Gorazd
Uninstalled and installed again. It says all is good, but there is no menu, toolbar, command,... Anyone else got it to work?
Gorazd Rajh
I have the same issue! Installed the AC connector from the Omniverse Launcher and no menu option in ARCHICAD, no toolbar, palette or WE setting either. Nvidia has no support other than an empty forum topic. Could anyone make this work?
