Morphs have their own fields for Area (by storey) and Volume (by Storey), which are different to the fields for other elements and objects.
So you will need to add those fields as well - they will then be blank for the other elements.
If you are using version 24, you could try using a segmented beam.
You should be able to to create beams with various segment sizes and tapers.
Here is one simple example.
