partial structure, dimensions and exporting to dwg
using partial structure and have separate set of dimensions on "entire model" and "without finishes" when translated to a dwg both sets of dimensions show up making a bit of a mess. Can't locate a setting in the translator... am I missing something and if not does someone have a work around. Thanks
1 REPLY 1
In the DWG/DXF Translator Dialog there is no setting that controls this.
The only thing I can think of is separate Layers.
You should place these dimensions for these different Partial Structure Display options on separate Layers in ArchiCAD.
Then in AutoCAD you will be able to display or hide then by turning their Layer On/OFF.
