pdf convertor
Can anyone recommend a simple free driver that will create pdfs from word etc
1 REPLY 1
CutePDF works fine, although I still tend to use the Amyuni PDF printer that was supplied with AC10 more often as it give better control of the image compression (and therefore the file size).
I presume you are not using Word 2007, as this comes with it's own built-in PDF creator. Just File>Save-as and select PDF/XPS.
There are also a few more PDF printers recommended on this thread - http://archicad-talk.graphisoft.com/viewtopic.php?t=28053
Hope that helps.
