preparation for the calculation of
I started studying computing gear and got into the problem.
When you find "ArchiCAD 13 Calculation Guide" and the Guide can not find the necessary tools
Edit Database
New Properties
Edit Properties
Last Selection's Properties
Link Properties to Criteria
Maybe someone could help, in advance grateful.
Faced with the problem that the manual can not find the command in Options> Work Environment> Layout Command Chart> Menus
Edit Database
New Properties
Edit Properties
You need to create this menu yourself. Go in the Work Environment / Command Layout Schemes / menus and choose at list the option 'by theme'
Look for the calculation theme and add the actions to a new command-menu.
Master Script
I was not looking there.
Thank you very much, and I hope to help in the future on this topic
