problem with saving .3ds file
Hello! i have problem with saving project as .3ds file. IT takes long time then archicad freeze (not responding) and in the end it didn't save anything.
Daniel Kovacs
Dear juliavy,
This might be caused by a bug in ARCHICAD that the export process (to 3DS format) may fail when you have objects placed that use picture files (eg. Picture 21, Fireplace 21, etc.).
Please try deleting/hiding the above mentioned objects before the export, and if that doesn't help, try removing all objects (because there might be other objects using pictures like this).
I hope this helps,
Daniel Alexander Kovacs
GRAPHISOFT
Daniel Kovacs
Dear juliavy,
I hope this helps,
GRAPHISOFT
thank you - it was problem with archicad - picture files gdl
