Collaborate forum
problem with saving .3ds file
Hello! i have problem with saving project as .3ds file. IT takes long time then archicad freeze (not responding) and in the end it didn't save anything.
1 ACCEPTED SOLUTION
Solution
Daniel Kovacs
Dear juliavy,
This might be caused by a bug in ARCHICAD that the export process (to 3DS format) may fail when you have objects placed that use picture files (eg. Picture 21, Fireplace 21, etc.).
Please try deleting/hiding the above mentioned objects before the export, and if that doesn't help, try removing all objects (because there might be other objects using pictures like this).
I hope this helps,
Daniel Alexander Kovacs
GRAPHISOFT
2 REPLIES 2
Solution
Daniel Kovacs
Dear juliavy,
I hope this helps,
GRAPHISOFT
thank you - it was problem with archicad - picture files gdl
