Collaborate forum
property expressions, "NONE" or jump to next Line
lukaso
Does anyone know a good way to jump into a new expression line (Add button)?
Case:
IF Typ is a wall show a wall-value If Not jump into next calculation.
I tried "None" but it won't work in all of the cases
I need this to shorten the expressions an keep a good overview.
Mac OSX - up to date
Archicad 6 to 25
6 REPLIES 6
Eduardo Rolon
That might be helpful,
AFAIK you might achieve that by placing each item in the Sequence section of Properties. The trick is that the sequence gives a result then it will stop there so you have to be creative on how to line them up.
For example if you a particular expression will work if it goes conceptually as this:
- If Category is Wall do this
- If Category is Slab do this
- If Category is Roof do this
In this case the expression will only give a result as long as the object has one of those categories. If the object has 2 of them then it will only give the first one that applies in the sequence.
So if the sequence is this:
- If Category is Wall ALSO do this
You will never get to the second line.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro 2.4 i9 32GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
lukaso
Thanx eduardo,
I figured that out to so far. For the expression I'm working on it would be of much help to have a "jump" option.
Tried many workarounds, but none of them really work...
Guess I'll have to wait for an update one day....
Thanks for the clear answer.
Lukas
Archicad 6 to 25
poco2013
FYI:
If you are using a sequence, you do not necessarily have to use if statements.
You can take advantage of the fact that Archicad will error check the statement beforehand for the applicability of the properties to the element selected.
If any property within the statement is not applicable, it will not try to do the statement but will skip to the next sequence.
So just use the calculation line applicable and Archicad will decide if it is valid for that type element.
The problem that you may get into is if you want to use the expression for different types which may have common properties like doors and windows. In that case use a empty property classified only for the element type of interest -- within the false return of a single line if statement.
This approach creates a single line statement for each element type. So you can use one expression for several different types (one sequence for each element type) without resorting to chaining ifs.
Gerry
Windows 10 - Visual Studio 2019; ArchiCAD 25
lukaso
thanks poco, in my case i need the if to ask for the classification...so i cant go without an "else". I would need a jumper property for each classification.......not to happy with this workaround
Archicad 6 to 25
Red
I assume there still isn't a feature as an ELSE?
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
lukaso
No there isn't. But there is IFS now (it has no ELSE at all)
By the way, I'm totally happy with the workflow poco explained.
Archicad 6 to 25
