If it is a Graphisoft library part then it gets a bit more complicated.
Because in future they may issue a new updated library and you will lose any modifications you made.
All the macros in GS objects will add another layer of complexity too.
So you will want to "save as" the object with a new name and then use that in your projects.
It could be in the 'Embedded' library in which case all users opening that file will have it already.
Or you could place it in an 'Office' or 'Project" library that you need to update on every machine or have it on the network so that all machines can access that one library.
