Teamwork & BIMcloud
"Close" vs. "Leave" - No 'close' available for one user
rob2218
How or what toggle/button whatever I have to activate to make this one user in our team be able to "CLOSE PROJECT"?
I've asked her not to "LEAVE" the project database since leaving it is not good.
Please help.
RR
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
8 REPLIES 8
The command in AC14 is called "Close Project". In AC13 it was called "Close".
Maybe the Work Environment was migrated to AC14 than the Close Project command may not be available.
Can this be the cause?
rob2218
This teamwork project came from an IFC file.
there was no migration from 13.
How do I get the "close" or "close project" back on the "FILE" drop down menu? it's the weekend coming up and we shut down the computers and I've told all users not to "LEAVE" the project but quite frankly I have no other option. We don't leave the computers on as a policy for the weekend so what do I tell this user???
i>u
Edgewater, FL!
SOFTWARE VERSION:
Erika Epstein
Rob,
CLOSING archicad is all you have to do, ALTHOUGH SEND AND RECEIVE first is advisable. You can turn the computer(s) off.
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
David Maudlin
Rob:
You can modify the Work Environment > Command Layout Schemes > Menus, remember to Redefine the scheme or save a new scheme to retain the changes. You could create a custom Work Environment to install on all computers in your office so there is one common WE for an office standard.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
rob2218
David,
where would I get the "close project" or the "close" (which ever the case may be) function from?
From which other menu do I acquire this icon and function to drag into the "FILE" menu?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
David,
here's the screen I see on MY machine, but on the other users....I can't seem to locate where throughout the other menus can I grab the "Close project" or "Close" command and drag it into her "FILE" menu....
i>u
Edgewater, FL!
SOFTWARE VERSION:
On the right side double-click the File menu to enter it.
Then the items on the left will become enabled and you can drag it to the right or click the "Add Selected" button.
rob2218
thanks all.
I spoke to David here locally.
He was able to walk me thru exactly what Lazslo was stating.
again...thanks all.
i>u
Edgewater, FL!
SOFTWARE VERSION:
