"Corrupt XML" when trying to import Properties from v20 to v22
matjashka
Hello All,
Should I be expecting that custom Properties cannot be imported from an older version of ArchiCAD?
I keep getting the same error message when exporting from v20 8005 and then importing into v22 3006, about a corrupt XML file (import fails).
Thank you,
Matt Krol [LinkedIn]
BHMS Architects and Planners, Chicago
AC 10 ... 26 USA
1 REPLY 1
matjashka
OK, I resolved the problem by opening the source project in v22 and then exported those same properties from there. It appears that v22 has more advanced export/import engine with more options. This worked nicely.
Note: after import, add Custom Classifications from the newer version to your older Properties (if needed).
AC 10 ... 26 USA
