Teamwork & BIMcloud
"Received data cannot be merged into your local copy"
I have a teamwork file in v21 that is getting this error message every few days. It initially only occurred for one user but is now affecting multiple users.
I have deleted the local teamwork data for each user which helps for a couple of days but it always comes back. First time I've encountered this and can't find any info online.
Any ideas?
5 REPLIES 5
Noemi Balogh
Hi ponaelius,
This could be caused by a corrupted element or database connecting to your project.
What I would try:
1. Ask all users to send data
2. Save a .pln from a user's machine where you still can Receive
3. Open the project with 'Open & Repair'
4. Re-share the project to the server
If it doesn't help, I would suggest to contact your local GRAPHISOFT Partner or send me a private message and we will try to sort this out.
Kind regards,
Noémi
Noémi Balogh
Community Expert, Admin
Thanks Noémi,
I had tried re-sharing to no avail.
Turns out errors were coming from the “Downspout Complex” object, specifically the "M_DS" macro.
It seems it is possible to create a conflict with the length of the downspout and the thickness of the pipe, once I isolated and removed these, the teamwork error appears to have gone as well.
I keep receiving this error on a very large teamwork project, causing all work done since last send/receive to be lost, unless I save down and manually copy elements/changes over to the teamwork file. How did you determine which object was giving you issues? This is a very large teamwork file and I can't delete elements one by one.
We have recently migrated the project to AC22, and in that process, saved down and open/repaired the file before migrating.
Thanks in advance!
Make sure you have your work environment set to write reports. Then go to the 3D window and turn all layers/filters on and you'll most likely be interrupted with an error report which will tell you which part of the model is having issues.
It may be a model element such as a mesh/slab or it may be part of a library object which is generally a little trickier to fix.
Thank you for the help. Turns out there were a lot of repeated errors in the report, and a lot of sneaky degenerated elements that I had to hunt down and eliminate. But great success! No more crashes since. Thanks all.
