.xyz files
Can an .xyz file (presumably a point cloud from another application) be opened or viewed in ArchiCAD?
6 REPLIES 6
mikas
Yes it can.
I think the file must contain the color values for each point, ie.
x,y,z,R,G,B
x,y,z,R,G,B
x,y,z,R,G,B
At least in AC19. Not sure about AC20.
AC25, Rhino6/7+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RX6800XT/W10ProWS
David Maudlin
bobup:
Yes. In the AC 19 Help files see: Interoperability > File Handling and Exchange > Working with Point Clouds > Import Point Clouds.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Thanks David, I believe the point cloud imported correctly. At least I can see it in plan view. I tried to view it in 3D but it's not showing up. I'll experiment with this and see what I come up with.
Thanks again.
David Maudlin
Roy:
Here is a Help file for point cloud issues: Point Cloud – Troubleshooting Guide
HTH,
David
The troubleshooting guide was a big help. It helped solve a few related issues. It turns out that after zooming out with the wheel on the mouse in 3D, I still couldn't see the point cloud. I then, after your reply, hit the zoom to extents button and the image showed up. It was there all along.
Thanks for your replies as I would have been trying for days to figure this out.
David Maudlin
Roy:
Thanks for posting back, glad that helped.
David
Learn and get certified!
