Advice - Large drone scan mesh into Archicad
Aazmatazz
Hi guys,
Im looking for a bit of advice.
We have survey drone data from a site, which has been supplied to us as a 2023 sketchup file.
Archicad throws up errors when trying to open (AC can only open skp files from 2019 and beyond).
I opened the file in sketch up and it runs fine.  I saved the file out as an earlier skp file, imported that into AC and it worked!
The problem is the mesh is just over 1 million polys, so it grinds AC to a halt.  The mesh seems to work absolutely fine in both Sketchup and Blender though so im wondering if I've missed a setting or im approaching the import wrong?
Any advice would be much appreciated as im pulling out my hair on this one.
10 REPLIES 10
Nurbs
Hi Mike 96,
Please take a closer look at CloudCompare. The output can be point files (xyz, txt etc.) as well, not only Point Clouds.
The goal is to reduce the number of points in a way that Archicad and your hardware can handle it. AC needs point files with only 3 columns (x,y,z) in it and no additional point data. With this AC can create a mesh which you can work on.
I agree that a mesh with a million points makes AC slow down....but do you need this density to get some buildings placed?
AC16 - AC29, Rhino 5-8. Alienware WIN 11
