2025-02-07
06:52 PM
2025-02-11
05:04 PM
Anyone using version 28 experiencing the inability to drag and drop a dwg or add it via. file/external content/place external drawing?
When you go the file/ex route and look at the available file formats .dwg is gone.
Operating system used: Windows 28.0.2 USA Version 3110
Solved! Go to Solution.
2025-02-11 05:24 PM
Hi Laszlo,
I had to do a re-install with a fresh download to get it fixed.
2025-02-07
11:29 PM
2025-02-11
05:04 PM
Does not seems to be the same dialog for the place external drawings formats, here is what I get in AC 28.0.2 Mac:
2025-02-10 02:22 AM - edited 2025-02-10 02:23 AM
Are you using the full commercial versions of Archicad, or the Start/Solo version?
I just looked at my options when I place a drawing and I see this.
2025-02-11 05:06 PM
If you go to the Options > Add-On Manager Dialog, do you see the DWG/DXF Input/Output Add-On listed?
Is there a checkmark next to its name in the Load column? That indicates that the Add-On is loaded into Archicad properly.
2025-02-11 05:24 PM
Hi Laszlo,
2025-02-11 05:28 PM
OK, great, so it was resolved.
