Convert pln to DWG/DXF
Hnas
is there a tool to convert files from pln to DWG/DXF without archicad?
regards
hnas
Miha_M
I haven't seen any, ever. I don't think there is one.
| Archicad 4.55 - 26
MudratDetector
Be aware that a review of the resulting .dwg file is most likely necessary.  We use the linked method above that is built in to ArchiCAD to get the .dwg file, but also post-process the results.
Post processing is done with .lsp and generates this report.  The things we scrub are based on what we hear from our consultants using the .dwg files.  A report of the results is generated and similar to this:
;;;	number of WIPEOUTs found and erased.
;;;	number of WIPEOUTs remaining in the drawing.
;;;	number of entities in the drawing after each of these cleaning operations:
;;;		- OVERKILL
;;;		- JOIN plines on layer "A-FOUNDATION"
;;;		- ERASE solid hatch patterns.
;;;		- ERASE point entities.
;;;		- CHANGE entities on layer "0" to layer "0-ArchiCAD".
;;;		- Set DRAWORDER for layers "a-wall-extr", "a-wall-demise", "a-wall-corridor", and "a-wall-intr" to front.
;;;		- FREEZE / THAW layer "a-zone-otln".
;;; Files cleaned by this script:
;;; C:\ARCHICAD PUBLISH\DWG\DWG_Unit Plan Cond. 1\2020061_Unit A2 HC_Cond 1.dwg
... Delete WIPEOUTs
... BEFORE:  Erasing 544 WIPEOUTs.
...  AFTER:  No WIPEOUTs found.
+++ Number of Entities
+++ Before           anything:  2201
+++ After            OVERKILL:  2201  (0)
+++ After                JOIN:  2201  (0)
+++ After   ERASE solid hatch:  2179  (22)
+++ After        ERASE points:  2169  (10)
+++ Selected for "0-ArchiCAD":  1
+++ Selected for    DRAWORDER:  351
+++ Status of   "A-ZONE-OTLN":  ERASED from file
Chris Gilmer
Intel i9-12950HX CPU @ 2.30GHz, 16 cores
NVIDIA GeForce RTX 3080
48.0 GB RAM
Windows 10 Pro 64-bit
