2016-11-23 07:59 AM
2016-11-23 09:04 AM
2016-11-23 10:30 AM
2016-11-23 10:34 AM
Aissa wrote:I haven't tried it with a DWG as the trace but certainly works with lines, splines or other elements in a trace.
The technique doesn't work on Trace Reference. The DWG file has to be in the same view where you're creating your site contours using Mesh Tool.
2016-11-23 10:38 AM
Barry wrote:I just tried and it does work.Aissa wrote:I haven't tried it with a DWG as the trace but certainly works with lines, splines or other elements in a trace.
2016-11-23 11:00 AM
2016-11-23 11:06 AM
2016-11-23 11:07 AM
2016-11-23 11:18 AM
Barry wrote:Yep, you have to use Merge...and yes, you also have to consolidate. Quite tedious exercise if the surveyors file is in DWG format.
How did you place the DWG.
I simply merged it into the plan and it worked fine.
If placed with the 'Drawing' tool or maybe as an XREF it won't.
Should work though if you explode it.
Can you select a contour on its own?
Is that what you were showing in that last image or was that a spline you added.
If they are all separate lines you could try the 'consolidate line' tool but they would all need to touch or overlap to consolidate to a single line.
Can you share the DWG?
Also what version of Archicad are you using?
2016-11-23 11:30 AM
