2021-03-04 06:46 PM
Solved! Go to Solution.
2021-03-09 12:47 PM
2021-03-09 12:47 PM
2021-03-12 12:12 PM
2021-03-12 01:31 PM
Spato wrote:EDIT : Actually, I was thinking Archicad determine the orientation From/to because of the placement of the "Sun" at the beginning. But that's not the case, Archicad determines it only by the side of opening, if it opens inside or outside.
Thank you very much for your answer. That explains everything for the limitation of Graphic Override, wasn't finding any documentation about it.
I manage to create the property "ORIENTATION" i was looking for :
IF ( OR ( ToZone = "Corridor"; ISUNDEFINED ( ToZone ) ); FALSE; TRUE )
Still using only schedules, helps to find in my case bad-oriented windows/doors.
2021-03-12 05:22 PM
IF ( OR ( {Property:General Parameters/To Zone} = "Corridor", ISUNDEFINED ( {Property:General Parameters/To Zone} ) ), TRUE, FALSE )
