Export IFC with local East/North coordinates but real world Z (sea level) coordinate
CarlM
I am trying to export an IFC-model with our local coordinates, but the real world z-value (defined with sea level).
Can this be done? - I can only find using either strict Surveu Point, or Project Origin in the IFC- translator (Geometry Conversion for IFC Export/Define IFC model position by:).
Or do you have to do a manual z-move of the model before export by the sea level value?
Looking forward to hearing your recommendations/suggestions!
Thanks!
AC 27 SWE, 64-bit
Windows 10 PRO
HP ZBook Fury 16 G9 Mobile Workstation, i9-12950HX, Nvidia RTX A4500, 64GB ram
5 REPLIES 5
CosminF
Hi!
You can try adding a Survey Point and define the parameters for IFC there, it may help:
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Hi!
Thanks for your quick reply!
I have the SP defined - I export dwg's in real world coordinates, but in this case I need the local X and y coordinates but the real world (sea level) z-coordinate in the IFC model.
AC 27 SWE, 64-bit
Windows 10 PRO
So you need a hybrid display (local + global) -  it was a misunderstanding on my part then with my previous reply.
I do not know how you would achieve this, maybe a feasible workaround would be to use global coordinates everywhere but mark the origin point at 0.0 (I just learned about it, the place called Null Island) and the Z value you desire. Then the X Y local would match X Y Global. But your project wouldn't be georeferenced anymore.
Yes - a hybrid. But I want to work near local origin, not in the real world coordinates (too far away).
I guess I'll have to export the IFC, merge it in a new instance of Archicad, elevate the entire model to the correct real world z-value, amnd save it as an IFC again.
AC 27 SWE, 64-bit
Windows 10 PRO
On the Learn Portal, there is a Workflow Guide about the Native Survey Point in Archicad, which covers this topic in detail.
Setup info provided by author
