Maxon Freeform in ArchiCad
"SPECIAL ANNOUNCEMENT – JUNE PROMOTION!
Graphisoft and Maxon are happy to announce a new partner solution for ArchiCAD called FreeForm. Based on Cinema 4D, FreeForm allows users of ArchiCAD to edit elements of building models as parametric primitives; with extrusions, holes, planes, points and paths; or with deformers and form generators, providing total design freedom!"
I'm not sure what this is, but it sounds pretty interesting. Total design freedom? I like that. Anyone care to comment.
111 Replies 111
Dwight
all is XFORM.
so sorry.
Dwight Atkinson
You mean it just describes the mesh!!???
Ok, i got it. For a moment i thought all my modeling problems where solved.
TomWaltz
Well, at least someone finally figured out what XFORM does.....
Tom Waltz
Dwight
XFORM,and other GDL statements like it aren't useful to the GDL scripter because they aren't parametric - yes, they do just describe the facets and surfaces in a non-parametric way. Just like all of the prior "GDL" writing tools that have been foisted on us - the computer world doesn't see form logically (neither do most architects but that doesn't stop them) - but who cares since:
the element can go back to Freeform to be edited.
Dwight Atkinson
stefan
If the element goes back to Freeform, is it still a mess, I mean mesh, or can it be using the HyperNURBS and other parametric features from Maxon Cinema4D?
Archicad-user since 1998
my Archicad Book
What i find "stupid" is that i will do the work in freeform using primitives and numbs and then save it as a mesh. And if i want to edit it again, freeform will import it as a mesh. That means all parametrics of the surface are lost.
If i want to alter a little bit the curvature of a surface then i cannot.
I think it would be easier to create a true langruge converter.
What i mean is. When i create an object in freeform (or c4d) there is actually a history of actions. If this was translated, we would have a genuine gdl object and not a mesh
Dwight
You will not be using it, then?
Dwight Atkinson
At first i said, this is it. What i was dreaming.
Now i just say, i ll have to use it a little bit to decide.
Rakela Raul
http://www.archpaper.com/feature_articles/10_05_next_dimension.html
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Dwight
ooo.baby!
With THAT software, I'll bet we can all afford to build structures like that! Those authoritative swoops will bring economy and confidence to our contractor's minds.
Dwight Atkinson
