2009-12-22 11:41 PM
2009-12-23 04:16 AM
2009-12-23 04:48 PM
Matthew wrote:Yes, the MEP Modeler has Clash Detection. It creates Mark-UP entries of the Clashes it has found so you can visually check where MEP stuff intersects itself or other structures.
I believe the MEP add on has clash detection capabilities but I haven't had time to check this out yet. I suspect it may only be useful with models from AutoCAD MEP which would be quite limiting if true.
2009-12-23 08:23 PM
2009-12-24 07:51 PM
2009-12-27 02:00 PM
2009-12-27 05:28 PM
Krippahl wrote:I'm not so sure about this.
Also, ArchiCAD being a modeling software, it taxes the system much more than non modeling ones, like Solibri, VICO, or AtLantis.
I suspect it will always be faster to check this kind of stuff on a non modeling software, as it is always faster to render in a non modeling software.
2009-12-28 01:40 PM
2009-12-29 08:41 AM
Krippahl wrote:I think we are pretty much on the same page with all of this. There are two distinct aspects to clash detection/coordination. One is trying to get the model right in the first place by linking other trades into the authoring programs. The other is checking all the results together independently in the checkers. This is the most thorough and effective approach and probably always will be.
From a complex model team structure point of view, where you have someone doing architecture, another structure, another H VAC, and so on, having a team leader who verifies everything outside a modeler makes sense. This way you can keep each role independent, with much better quality control.
2009-12-30 09:02 AM
Matthew wrote:Solibri provides also a direct link between ArchiCAD and Solibri Model Checker as an ArchiCAD plugin. The user can send model to Solibri without exporting an IFC file. It is faster than ArchiCAD IFC export and the user can also transfer selections between Solibri and ArchiCAD. AC11/12/13 for Windows and Mac is supported in the latest plugin release.
Solibri works very well with ArchiCAD IFCs so it probably rates as the most compatible, especially since IFC export from AC13 seems to be significantly improved (I am just getting around to serious testing right now). The main drawback is that IFC export can be quite slow and the files quite large. On the plus side Solibri offer much that Navis does not.
