Setup List Schemes Dialog
Can someone tell me how do I get to the Setup List Schemes dialog in AC 13. I would like to create a cabinet schedule. Based on everything I read, this would be the best place to do so, but I cannot figure out how to get to the dialog box. Any assistance would be appreciated.
That's actually not the best place to do a cabinet schedule. (But, to get to List Schemes, and more, you need to customize your Work Environment and add more Calculate menu options to your menus. As what appears to be a beginner, I do not recommend this unless you've determined that an element schedule cannot do what you want.
To open the Element Schedule schemes, either:
1. Menu - Documents > Schedules and Lists > Schedules > Scheme Settings... (depending on how your menus are set up) ... or, more easily:
2. In the Project Map of Navigator (or Organizer), right-click Schedules and select Scheme Settings
3. another half dozen ways...
Create a new scheme with criteria that filter only your cabinets and display the fields that you want/need, which may include some 'custom' fields into which you can enter information associated with each cabinet.
Karl
