Share surfaces with textures between projects
Hi
I've created a new surface (kitchen tiles) with a specific texture (.jpg), i've used attribute manager to append this surface to a different project, but after I make the import it shows no surface (violet chess pattern). I'm asking if there is a workaround to import "old" surfaces to a new project.
Thanks for your help in advance!
2 Replies 2
Dave Seabury
Make sure you copy the jpeg in to a loaded library for the project.
Just a guess
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
Just a guess
That is a good guess.
When ever you see the checker board pattern, it means the image file (JPG, PGN) is not in a loaded library.
The image file is just referenced by the attribute - it is not actually transferred with it.
