Sketchup to Archicad Construction Elements.
I have a sketchup file that I would like to convert to an archicad file. I have used the google earth connections to convert it but the sketchup file will only come through as a solid object. I then selected the object and converted it to morph objects. I would like to be able to change these morphs into walls and slabs. Is this possible?? If so how do I go about it?? I have Archicad V16.
1 REPLY 1
Morphs can only be saved as an object - unfortunately not as walls, slabs, etc.
The best you can do is use their position to model in some real walls and slabs - then delete the morph.
