According to Graphisoft, properties that require significant calculations by Archicad are not available to the Graphic Override criteria. This is due to a performance problem. Unavailable properties will not show up in the Criteria ADD options. In expressions, if you use any of these "unavailable" properties, in any way, that expression will also not be available to GO.
Gerry
