We value your input!
cadimage Bracing
Hi
I am trying to use the cadimage brace tool for a relatively simple design, after selecting walls i need braced and entering the bracing settings via calculate bracing, I note all the building dimensions and cladding weights details are greyed out. If i enter ok to see what it does i get the message
" No exterior walls selected, i.e having a composite starting with 'Ext'
All walls selected are in fact the default composite structure EXT: Stud 90
Not to sure whats going on here but any help would be really appreciated
Thanks
19 REPLIES 19
I have no idea of how this add-on works, but is it case sensitive - EXT - Ext?
Cadimage also have their own support centre so you might want to try there.
It doesn't appear to be case sensitive, i just tried it with both upper & lower case.
Please let us know what the issue is when you have it fixed.
Will do, Waiting on response atm
So for those that were interested, the walls were approx 1 hundredth of a degree out causing the error
Thanks for that, there is a free add on marker somewhere on the web, that will tell you if your walls are orthogonal or slightly out, useful for trainees until they learn to use the shift key more.
Ralph Wessel
Mentor
We're correcting that – the tolerances were set far too tight.
Ralph Wessel BArch
Software Engineer Speckle Systems
Hi Ralph, if you are doing some work on the bracing tool I have a request.
When all the parameters have been input, such as dimensions, bracing set etc. can they be saved?
Quite often I have to go back out the DBX to get a dimension or other for the bracing input, then when i re-open i have to input all of the info again!
Ralph Wessel
Mentor
We're working on something that should solve that issue. Best approach for feature requests is to contact our support team – they add it to development database so it can be tracked from specification to release.
Ralph Wessel BArch
Great, thanks Ralph & will do
I am looking forward to working with a new improved bracing tool.
