3 weeks ago
- last edited
3 weeks ago
hi . I'm trying to export my model into ifc (revit) but the wall surface and texture in not the same.
How can I export texture properly? thank you.
3 weeks ago
- last edited
3 weeks ago
It is not possible unless the program you use to open the IFC file has a translator capable of converting IFC materials into the program's native materials, similar to how Archicad's IFC translator works.
If you are going to open the IFC in Revit it might be possible if you use this:
https://community.graphisoft.com/t5/Graphisoft-Insights/IFC-Model-Exchange-with-Archicad-for-Revit-2...
