Read articles about model- and data exchange with 3rd party solutions: Revit, Solibri, dRofus, Bluebeam, structural analysis solutions, and IFC, BCF and DXF/DWG based exchange, etc.
Articles
Open BIM Workflow Improvements
Open BIM Workflow Improvements Graphisoft’s Open BIM approach continues to be the focal point, through which we support design teams in efficient multi-disciplinary collaboration. IFC4 certification for Architectural Reference Exchange for Import Dur...
Import/Export File Formats in Archicad
File Format Categories Archicad Formats Archicad BIMx Teamwork Library PlotMaker Diagnostics Other Formats CAD 3D/BIM Vector Graphics Image Point Cloud Video Documentation Archicad Formats Archicad Project Formats import / export .PLN Archicad Solo P...
wp-content_uploads_2019_07_ImportIcon_18x18.svg wp-content_uploads_2019_07_ExportIcon_18x18.svg wp-content_uploads_2019_07_ExportIcon_18x18_30.svg wp-content_uploads_2019_07_ImportIcon_18x18_50.svg
3DStudio In Add-On
This ARCHICAD Add-On can convert 3D Studio Max (.3ds) files to ARCHICAD as GDL objects. The conversion process can be customized by the user. Download and install "3DStudio In" Add-On You can download this Add-On amongst other Goodies by clicking on ...
wp-content_uploads_2017_05_3ds-menu-1024x488.png wp-content_uploads_2017_05_Currently-Loaded-3ds-file.png wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_2017_05_3ds-conversion-options-853x1024.png
Export Component-Level Data to IFC
Export customized data for individual components in IFC format In earlier versions of Archicad, we couldn’t export customized data for individual components (not just elements as a whole) in IFC format, so component-level quantity reports required wo...
EmokeCsikos_0-1653336603164.png EmokeCsikos_1-1653336603175.png EmokeCsikos_2-1653336603180.png EmokeCsikos_3-1653336603186.png
Faster Export to FRILO
Frequently exporting SAF files to FRILO can be time consuming Structural engineers who use FRILO are currently spending quite some time exporting SAF files by selecting a save location and setting the path for export each time, which interrupts the w...
MoaazHassan_0-1653304653486.png MoaazHassan_1-1653304653488.png MoaazHassan_2-1653304653489.png MoaazHassan_3-1653304653492.png
SAF Translator Improvements
Adjusting SAF Translator settings Currently, structural engineers can create and adjust structural analytical models in Archicad and eventually export them to the structural analysis software via SAF translators. However, in earlier versions of Archi...
MoaazHassan_0-1653306242486.png MoaazHassan_1-1653306242492.png MoaazHassan_2-1653306242497.png MoaazHassan_3-1653306242499.png
Splitting Rules of IFC Mapping
This post is to follow up on the previously published ‘Syncing Zone Cover Fills and Floor Finishes’ article where we mapped the Cover Fill value of the Zones to a custom made IFC property and made it appear in the Zone Stamp, this way saving some tim...
Rhinoceros — GDL Converter
The Rhinoceros - GDL Converter is a part of the Rhino – Grasshopper – ARCHICAD Toolset. Create native ARCHICAD objects in Rhinoceros With this toolset, designers can save a selected part of a Rhino model in a native ARCHICAD object file (.gsm or .lcf...
Rhinoceros Import/Export Add-ons
The Rhinoceros Import/Export Add-ons are parts of the Rhino – Grasshopper – ARCHICAD Toolset. Exchange models in Rhinoceros native file format Designers may choose to work with a "reference model workflow" by exporting and importing models between AR...
Open BIM
OPEN BIM is a universal approach to the collaborative design, realization, and operation of buildings based on open standards and workflows. OPEN BIM is an initiative of several leading software vendors using the open buildingSMART Data Model. Why is...
wp-content_uploads_2020_05_banner-open_bim.png wp-content_uploads_2020_05_logo-tekla.png wp-content_uploads_2020_05_logo-graphisoft_2X.png wp-content_uploads_2020_05_nemetschek-group-logo.png
Importing 3DS Files as Objects
Using 3DS content can be a great tool in building up a custom library. In order to import 3DS files the 3DStudio In add-on will need to be installed. The add-on is part of the Goodies installer. After this package is installed, follow the steps below...
wp-content_uploads_2018_09_3DS-Import-Step-1-300x174.png wp-content_uploads_2018_09_3DS-Import-Step-2-300x219.png wp-content_uploads_2018_09_3DS-Import-Step-3-1.png wp-content_uploads_2018_09_3DS-Import-Step-4-1.png
Coordinates and Orientation
Create the ARCHICAD model close to the ARCHICAD origin, which is indicated by a black cross on the floor plan. Loss of precision or malfunction can be experienced if the project elements are located very far from the project origin or from each other...
wp-content_uploads_ifc_IFC_Exchange_Best_Practices.1.03.1.png wp-content_uploads_ifc_IFC_Exchange_Best_Practices.1.03.2.png wp-content_uploads_ifc_IFC_Exchange_Best_Practices.1.03.3.png
3D Studio Files in Archicad
Import 3ds Max Files (.3ds) With the help of '3DStudio' In Add-On you will be able to convert .3ds files to Archicad GDL objects. By default, it is not integrated into Archicad. You can find a detailed description about the Add-on and how it works on...
wp-content_uploads_2017_01_save-as-out.png wp-content_uploads_2017_01_save-as-1.png wp-content_uploads_2017_01_convert-units.png wp-content_uploads_archicadwiki_3dstudio--3ds.png
mtron Graphisoft
  • 85325 Views
  • 0 comments
  • 0 likes
Point Cloud - Troubleshooting Guide
Huge Point Clouds can't be opened in ARCHICAD Affected version: 19 and later | Severity: workaround applicable | ID: 191641IssueImporting Point Clouds that result in a .lcf file larger than 4GB cannot be done because of the limitation of the .lcf ext...
wp-content_uploads_2015_04_Antialias.png wp-content_uploads_2015_04_zoom-problem-pointcloud.png wp-content_uploads_2015_04_Point-cloud-Floor-plan-display-e1430230765971.png
Rhinoceros - GDL Converter - FAQ
What is the Rhinoceros - GDL Converter? The Rhinoceros® - GDL converter enables users on Windows platform to export a model created in Rhino, and import it to ARCHICAD (to both Mac and Windows platforms). The Rhino-ARCHICAD link converts Rhino model ...
wp-content_uploads_2015_05_table-300x243.png wp-content_uploads_2015_05_roof-shell-300x194.png wp-content_uploads_2016_08_Rhino-save-error-1.png wp-content_uploads_2015_05_Surface-Override-Rhino.png
External Content - Troubleshooting guide
The External Content Menu is missing from the File menu in ARCHICAD 19 Solo edition Affected version: 19 Solo | Severity: workaround applicable | ID: 200991 NOTE: This issue will be fixed in ARCHICAD 20 Solo. Issue The External Content menu is missin...
wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_2015_07_External-content-missing.png wp-content_uploads_2015_07_Navigator-Drawing-Manager.png wp-content_uploads_2015_07_place-external-drawing-WE.png
How to Open and Save 3D DWG or 3DS Files
3D modelling softwares have different engines to compute objects, they have their own file formats. The conversion between these applications goes usually in two ways: Using DWG/DXF format: the content of the file depends on the conversion system of ...
wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_archicadwiki_dwg-import-3d--2.jpg wp-content_uploads_archicadwiki_dwg-import-3d--3.jpg.png wp-content_uploads_archicadwiki_dwg-import-3d--4.jpg
automata Graphisoft
  • 26647 Views
  • 0 comments
  • 0 likes
