on
2012-12-11
02:09 PM
- edited on
2021-11-19
11:47 AM
by
Rubia Torres
When Save Plan dialog is displayed, choose DXF or DWG format. The Translator field in the Save dialog box lists the available translators. If you don’t know which default translator to use, choose Settings to open the DXF/DWG Translation Setup dialog. Each default translator listed at the top is briefly described in the Description field.
NOTES:
- If you recognize that files saved from ARCHICAD to DWG or DWF are unusually large, probably it contains Materials, Symbol Fills (e.g. gravel fill), Symbol Lines (thick dashed lines) that are exploded to thousands of small lines in AutoCAD.
- If you are working in AutoCAD and open a DWG that was originally saved from ARCHICAD, an Alert may appear. However, you should go ahead and work with the saved DWG in AutoCAD - no stability problems should result. Read more: AutoCAD alert with DWG written by ARCHICAD
How DWG data is imported by ARCHICAD depends on the settings used in the DXF/DWG Translator; this dialog box defines how elements in ARCHICAD will be interpreted when importing DXF/DWG files.
Depending on how the Translator is opened, not all settings will be available. For example, if the dialog box is opened during Save as operation, only the Save Options will be listed, but not the Open Options. If the dialog box is opened from the File>File Special menu then all options are listed.
Can anybody please tell me what the DWG file import and export limitations are in Archicad SE 2022 or you cannot do it at all period ?
The comparison chart is not completely available in English for comparing AC25 with ACSE 2022.
I saw the chart in German but I can’t read that one.
Thank you.
Edit: I found the link but this only compares AC24 with ACSE 2021 an older.
The limitations are just a bit too many for me at present.
I would need a photo realistic & sketch render tool to be included to be satisfied with SE2022 at least.
I would prefer all the power of AC full element creation, curtain wall tool inc etc.
I could go without teamwork and many other collaboration fields that are not applicable in a small firm.
I think ACSE is still a bit thin even for a small firm or a sole operator to be truly useful.
Please update your comparison matrix to include SE2022 with AC25 for now.
Hello!
I will join to the topic.
Is it possible to publish a Folder of DWGs in a way they are somehow aligned in the workspace?
I for example publish all the layouts into one dwg file
But when opening exported DWG back in Archicad or any other DWG software/viewver, the layouts are all around the workspace:
Is there any way that the publisher exports and aligns dwgs together?
Hi @mthd,
We have an updated comparison matrix between Archicad Start Edition 2022 and Archicad 25 available here. New versions can be checked on demand in this article.
Hi @tjasa,
Can you please enter your question in the dedicated forum? You have increased chances of getting help there.
Comments are currently disabled in articles. Learn more about recent changes in the platform here. Thanks for your understanding.
