on
2017-01-26
06:54 AM
- edited on
2021-09-14
10:20 AM
by
Rubia Torres
Once installed, the GRAPHISOFT Add-In can be located on the ribbon under Add-Ins.
If or when both the Revit Architectural model and ARCHICAD model are coordinated near the project origin (0,0,0), we recommend leaving the following options unchecked:
For more information about the options available in the GRAPHISOFT Revit Add-In, see http://tinyurl.com/hoe3fp9.
Architects may not necessarily require all of the intricate fittings/components for coordination purposes. Therefore, it is wise to hide these elements prior to export. This can be achieved in two ways:
1. Temporary hide/isolate command
An easy way to isolate Ducts/Pipes is to use Revit’s temporary hide/isolate command. View the Revit MEP model within a 3D View, highlight a duct, then use the sunglasses icon, followed by “Isolate Category”. Now, only ductwork is displayed in the 3D View; everything else will be temporarily hidden. You can also select two different categories, e.g. Ductwork and Pipework, then use the Isolate Category command to isolate elements of those types.
2. Filters
Another way to isolate elements is to create filters. Filters can be created within Visibility/Graphic Overrides (Press VG on the keyboard!)A key benefit of filters is that you can create rules to show/hide specific elements. (With the temporary hide/isolate command, it’s all or nothing.)
The screenshot below shows an isolated bathroom using filters to isolate the Revit MEP elements.
References:
You can read more about Temporary hide/isolate and Filters in the following reference guides:
Temporary hide/isolate: https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revi...
