Data Exchange articles
Articles
Export Component-Level Data to IFC
Export customized data for individual components in IFC format In earlier versions of Archicad, we couldn’t export customized data for individual components (not just elements as a whole) in IFC format, so component-level quantity reports required wo...
EmokeCsikos_0-1653336603164.png EmokeCsikos_1-1653336603175.png EmokeCsikos_2-1653336603180.png EmokeCsikos_3-1653336603186.png
Faster Export to FRILO
Frequently exporting SAF files to FRILO can be time consuming Structural engineers who use FRILO are currently spending quite some time exporting SAF files by selecting a save location and setting the path for export each time, which interrupts the w...
MoaazHassan_0-1653304653486.png MoaazHassan_1-1653304653488.png MoaazHassan_2-1653304653489.png MoaazHassan_3-1653304653492.png
SAF Translator Improvements
Adjusting SAF Translator settings Currently, structural engineers can create and adjust structural analytical models in Archicad and eventually export them to the structural analysis software via SAF translators. However, in earlier versions of Archi...
MoaazHassan_0-1653306242486.png MoaazHassan_1-1653306242492.png MoaazHassan_2-1653306242497.png MoaazHassan_3-1653306242499.png
Support of Multi-Segmented Columns and Beams
Graphisoft has focused on further streamlining multi-disciplinary design workflows. Archicad 26 enhances the collaboration between structural engineers and architects with important structural analytical workflow improvements. Structural elements wit...
GabrielDantas_0-1653306781866.png GabrielDantas_1-1653306781870.png GabrielDantas_2-1653306781872.png GabrielDantas_3-1653306781873.png
Splitting Rules of IFC Mapping
This post is to follow up on the previously published ‘Syncing Zone Cover Fills and Floor Finishes’ article where we mapped the Cover Fill value of the Zones to a custom made IFC property and made it appear in the Zone Stamp, this way saving some tim...
Revit to Archicad Exchange – Door Swing Issue
Recently came across an issue with door swings when IFC file is exported from Revit 2019 (19.2.10.7). The doors get mirrored when imported into Archicad or Solibri. This is a big concern as the submission drawings were produced with swing direction a...
Rhinoceros — GDL Converter
The Rhinoceros - GDL Converter is a part of the Rhino – Grasshopper – ARCHICAD Toolset. Create native ARCHICAD objects in Rhinoceros With this toolset, designers can save a selected part of a Rhino model in a native ARCHICAD object file (.gsm or .lcf...
