Data Exchange articles
Articles
ARCHICAD Export to DWG/DXF
Save as DWG: You can save a project view or layout from ARCHICAD to DXF and DWG formats. To save only one part of the view, use the Marquee to delimit the project and select Save As command. When Save Plan dialog is displayed, choose DXF or DWG forma...
automata by Graphisoft
  • 2892 Views
  • 0 comments
  • 0 likes
DXF-DWG Translator
Use this dialog box to define how elements in ARCHICAD will be interpreted when exported as DXF/DWG files, and vice versa: how the elements in DXF/DWG files will be interpreted when imported into ARCHICAD. Because of the difference between AutoCAD an...
wp-content_uploads_archicadwiki_dwg-dxf-dwgtranslator--picture.png wp-content_uploads_archicadwiki_moniker-images_checkmark.png
  • 440 Views
  • 0 comments
  • 0 likes
DXF-DWG Import Translator Settings
File/File Special/DXF-DWG Translation Setup By clicking on a Translator during import, you can see and edit its content in the fields below, which falls into five main groups: DXF-DWG Translator Settings Drawing Unit Select the correct value of 1 DXF...
  • 250 Views
  • 0 comments
  • 0 likes
Translator List.xml
The 'Translator List.Xml'file is located in the following folder: On PC: C:/Users//AppData/Roaming/Graphisoft/AC/Dxf-Dwg Preferences On the Mac: /Users//Library/Preferences/Graphisoft/AC/x86/Dxf-Dwg Preferences Translator List.XML is automatically cr...
  • 17 Views
  • 0 comments
  • 0 likes
IFC Workflow Between ARCHICAD and Revit Structure
Follow the steps below when collaborating with someone using Revit Structure. In the example ARCHICAD 15 and Revit Structure 2012 were used but the process remains the same for current versions. 1) Set Element Parameters Open the selection settings d...
  • 72 Views
  • 0 comments
  • 0 likes
IFC Workflow Between ARCHICAD and Revit MEP
Follow the steps below when collaborating with someone using Revit MEP. ARCHICAD 15 and Revit MEP 2012 were used in the examples below but the process remains the same for current versions of ARCHICAD. 1) Set Element Parameters Open the selection set...
  • 110 Views
  • 0 comments
  • 0 likes
DWG Layers' visibility in ARCHICAD
To control the visibility of objects, usually there are more Layers used in DWG projects. Let's see how can the different import options in ARCHICAD manage the DWG layers: Open File » Open To define how elements in ARCHICAD will be interpreted use th...
gkmethy by Graphisoft
  • 265 Views
  • 0 comments
  • 0 likes
XREFs
XREFs are External reference files: DXF or DWG filetypes which can be imported into ARCHICAD. It facilitates to collaborate with Sturctural Engineers. A common use for XREFs is to draw elements that are common to several kinds of drawings within a Pr...
  • 45 Views
  • 0 comments
  • 0 likes
Artlantis
Artlantis is a popular and easy-to-use rendering application for ARCHICAD and other CAD software. It is developed by the French software company Abvent Among the features of Artlantis are a real-time preview window that shows radiosity (illumination)...
  • 57 Views
  • 0 comments
  • 0 likes
Top Contributors
