Archicad 25 sudden file size increase
Norbert Kucsma
With Archicad 25 Graphisoft has implemented many exiting new features and improvements. For more information please visit this page .
Symptoms
At the same time the released Archicad 25 3002 build has raised an issue (DEF-6049), some projects might suffer from unwanted file size increase.
Diagnosis
The issue is caused by multiplying unused View Settings. Copying the Elements to a new file saves the model content, but this way you will also loose the View Map, Layouts...etc.
Solution
We are happy to share with you that the first update of Archicad 25 will resolve this problem. We do not know when Update 1 will be available for download yet, but once it is available, please apply the update to avoid the above described issue.
Note that the already increased files can be repaired only at Grahpisoft HQ. Feel free to contact your local technical support to get your file fixed. If you don’t know who your local distributor is please visit this site.
We sincerely apologies for the inconvenience this issue might caused you.
Browse more articles
Back to articles
