The content you are looking for has been archived. View related content below.
on 2019-10-02 05:42 PM - edited on 2022-10-28 01:35 PM by Giovana Benvenuto
Stories in Archicad, just as in real buildings, serve to divide space vertically and replicate the story structure of your real building.
Stories are ranges of height in space. Each story has a reference (level). It is the height of the horizontal plane at the bottom of the vertical range. The references of the stories are represented by Story Level Lines on Sections and Elevations.
Every element in Archicad is linked to a story, called the Home Story.
This article will be presented an overview of how to work with Stories:
When you work on a floor plan, you see the elements that are on that specific story or are linked to that story. Home Story is a parameter of the elements, so you can select, list, or filter the elements based on their Home Story.
You can set the position and visibility of an element in the Story by using: Home Story and Show on Story
Home Story:
By default, every element is automatically linked to the story where it is, but other elements, that are not in the height range of the story can also be linked to the same story. You can change the Home Story to which the element is linked at any time without changing the element's height or position in space.
You can link the top or the bottom of some elements, such as walls, slabs, columns, and stairs to stories in the project. It means that if you change the story height, the height of these elements changes too.
You can learn in detail how to work with Home Story in this article: How to change the Home Story of an element in Archicad.
Show On Story:
The Show on Story parameter defines the visibility of the elements on the floor plan and section, the options you can choose are:
Additional options for Roof, Beam, Slab, Mesh, and Object:
Learn in detail How to better control Slab and Mesh displayed on multiple stories.
To edit or create stories, you have to open the Story Settings dialog box. You can open the dialog two ways:
In the Story Settings dialog, you can
The elevation is the absolute height level of the story reference, the entered values can be positive or negative
Height to Next is the distance of the story reference from the reference of the next story. its reference to the next story reference, the inputs can be only a positive value.
You can control the height and vertical position of stories by setting up their Elevation or the Height to the Next values.
Another way to create a new story:
All renamed, and newly created stories will be immediately shown in the Navigator after confirming the inputs by clicking “OK”.
Make sure that you are in the right Tab. The current viewpoint is written in bold letters. Double-click the Ground Floor in the Navigator to switch to it.
Go to Design > Story Settings.
Click the name of the story you wish to rename, and type the new name.
Alternatively:
Right-click the story name in the Navigator, and choose the Rename Story command.
Use the Navigator or Story Settings to delete one or more stories by clicking on Delete Story.
Note:
Option 1:
Option 2:
This option goes with Coordinates and Orientation if a Survey Point is used. (Since the survey point is used, there is no need for hotlinking the model.) Set the Archicad elevation values in your model to the real-world Z coordinates and keep the Height to Next values the same. At export, the IFC will be exported to Real World Z coordinates.
Some articles that can help in detail:
Coordinates and Orientation - Graphisoft Community
Project Base Files for Coordination - Graphisoft Community
Project Base Files for Coordination – Explanation - Graphisoft Community
If you would like to learn more about Stories and Levels in Archicad check these articles:
How to use the Home Story parameter in Favorites
