on
2021-03-22
06:50 AM
- edited on
2021-11-26
02:29 AM
by
Rubia Torres
As of Archicad 24 Update 3, PARAM-O is part of the Archicad product and doesn’t need to be installed separately, as it is updated together with Archicad.
However, the previously installed PARAM-O (before Update 3) was installed separately as an add-on and the Archicad update will not be able to update it properly.
Read this article to learn what to do if you have PARAM-O already installed.
If you have an older PARAM-O version installed, please uninstall it.
Note:
Previously installed PARAM-O Add-On will not be updated when installing Archicad 24 Update 3. The Archicad update will be installed but it will give error messages:
Some Add-Ons could not be loaded.
For more details open the Add-On Manager.
After opening the Add-On Manager, you will see an alert next to PARAM-O.
In this case you will have to do the same and uninstall PARAM-O:
As of Archicad 24 Update 3, PARAM-O is part of Archicad and doesn’t need to be updated separately, as it is updated together with Archicad.
