Design articles
Articles
Custom Curtain Wall Junctions
Creating custom components from scratch using the default tools and saving them as objects is a relatively simple way to extend the content libraries thanks to the File/Libraries and Objects…/Save Selection as… command. However this menu doesn’t list...
How to Create a Basement Stair and Bulkhead Door
In order to efficiently model a basement stair and bulkhead door (i.e. not creating extra cutting bodies) elements need to be created and cut in a specific order. These steps are listed below 1. Make sure that a mesh has been placed around the outsid...
wp-content_uploads_2019_08_Screen-Shot-2019-08-07-at-9.23.03-AM.png wp-content_uploads_2019_08_Screen-Shot-2019-08-02-at-2.26.26-PM-1024x896.png wp-content_uploads_2019_08_Screen-Shot-2019-08-02-at-3.44.22-PM-1024x847.png wp-content_uploads_2019_08_Screen-Shot-2019-08-02-at-3.51.51-PM-1024x634.png
How to create cladding using the new Curtain Wall tool
With the new Curtain Wall tool, released on ARCHICAD 22 Version, it is possible to create many different Panel Classes straight from the Curtain Wall Setting Dialog. You can even create a Cladding Panel using the new GDL Panel Type called CW Composit...
wp-content_uploads_2018_06_Create_new_panel_class-1.png wp-content_uploads_2018_06_Type_Geometry.png wp-content_uploads_2018_06_Cladding-Skins-Scheme.png wp-content_uploads_2018_06_CW_Cladding.png
Curtain Wall Tool - Intersection Priorities
Before the revamped Curtain Wall Tool was released in ARCHICAD 22, intersection priorities were taken in count when creating a Curtain Wall, but not used as a creative tool. Boundary, Mullion and Transom frames did have a priority, but these were fix...
wp-content_uploads_2018_06_Screen-Shot-2018-06-19-at-12.03.44.png wp-content_uploads_2018_06_frames1.png wp-content_uploads_2018_06_edit.gif wp-content_uploads_2018_06_edit2.gif
Curtain Wall Tool - Projection Modes
After the redesign of the Curtain Wall Tool in ARCHICAD 22, it can have different projection modes on a floor plan view (found under Floor Plan and Section in the element's Settings dialog). These can be set for Uncut, Cut and Overhead components, si...
wp-content_uploads_2018_06_Screen-Shot-2018-06-14-at-14.30.34.png wp-content_uploads_2018_06_HC-template1.png wp-content_uploads_2018_06_HC-template3.png wp-content_uploads_2018_06_HC-template2.png
How to Speed-up Curtain Wall in ARCHICAD 22
You may experience the following whilst working with Curtain Wall in ARCHICAD 22: Working with Large Curtain Walls may cause some slowdowns Curtain wall may be faster in ARCHICAD 21 than in ARCHICAD 22 Working with Large Curtain Walls may cause some ...
Migrating Curtain Walls to ARCHICAD 22
Since there is a new Curtain Wall Tool in ARCHICAD 22 there are a few things you need to be aware of if you want to migrate your project that contains Curtain Walls from ARCHICAD 21 to 22. Generic Frame and Panel During the migration of the project „...
wp-content_uploads_2018_06_Screen-Shot-2018-06-07-at-14.17.46-300x214.png wp-content_uploads_2018_06_Screen-Shot-2018-06-07-at-14.29.54-300x244.png wp-content_uploads_2018_06_Screen-Shot-2018-06-07-at-14.37.22-300x181.png wp-content_uploads_2018_06_Screen-Shot-2018-06-07-at-14.21.16-1-300x175.png
